Hi folks.
My first post here - I'm doing motor repair and have a couple questions. The motor is a 1/10 HP electric motor for an Austin Air HM400 HEPA filter. While it is a high quality unit, their support sucks... E.g, they use proprietary hardware you can't just buy a replacement for and they will not sell you parts - they make you ship the darn thing back to them.
Anyway - the motor problem I originally thought might be a run capacitor problem, but after replacing that, with no avail, and realizing the motor rotor will not spin very freely at all, I thought it was time to take the motor apart and check out the bearings. The rotor shaft is mounted vertically. First up is the top motor shell:
[img:left]http://postimg.org/image/pf1ubs22r/[/img]
The rotor: (About 8" long total) (The "down" direction in the picture actually points up in the filter)
[img:left]http://postimg.org/image/4w619nuhj/[/img]
And finally the bottom part of the motor casing:
[img:left]http://postimg.org/image/rvcuh3ywz/[/img]
What I can't figure out - is what the heck those little "cotton" like shavings are doing inside the bushing... Seen best in the first picture. Note that the first picture is showing the top half of the motor flipped upside down. Normally those little cotton like thingies are somehow held in place even when that casing is flipped over. Granted the shaft has a collar on it, but it is not as wide as the opening to the bushing area. Not sure if this is making much sense - it's a bit hard to explain.
1) So can anyone help me understand what those things are - that are in both the upper and lower bushing enclosure within the upper and lower motor casings?
2) The motor was somewhat seized - but after cleaning it and the inner cylinder of the bushing, it will spin more freely - but before I re-assemble, I want to determine what to lubricate it with. Any advice?
Thanks
Thanks
