Posting this for a fellow Acadia owner.
Need your assistance. Just did the OA. Let me know what I should worry about. I usually get my oil change thru the dealer. Somehow, I got a feeling that I'm getting jammed with $$. So, I went with the quick lube chain. This time for sure, I know the shop is using legit Pennzoil Platinum Full Synthetic, 5W30 (I saw them opening the jar and poured onto the engine!). The only thing that I've noticed, was this time, I didn't have to do any top up. This time the engine didn't burn much oil. So, fellas, can you spare some time to fellow acadian and let me know where should I worry et al.
Prior to the oil change:
-I only drove the vehicle for about 15 kms, city driving with a couple of stops (school and coffee).
-I do remote start to warm the vehicle for the kids.
-And the temp outside that I usually run the vehicle (again, before the oil) is below 0 degrees Celcius.
I'm worried about the engine burning oil, as I used to top-up oil when I was using Mobil1 Full Synthetic. Do you guys suggest compression test from the dealer or is this normal for Acadia?
Thanks.
Thanks.
