I do understand that standard "analog" dials are the fastest way to pick up readings, but I've noticed that the distance between the needle and the base makes a difference in the reading. For instance, I'm trying to read the fuel gauge, and whether or not I perceive it's at the middle line depends on whether I center my line of sight at the center of the needle or I'm sitting straight up (where I perceive it to be lower).
I just find this interesting. I know there are some purely electronic readout systems, but they're not that common. I suppose these errors could be reduced if the needle is closer to the base.
