Originally Posted By: gregk24
It only starts when you give it gas, but as soon as you let off it shuts off. Here are the stored codes:
- 38 - brake switch circuit
- 41 - cylinder select error- mem-cal or ecm problem
- cam sensor circut (3.8 models)
- 42 - bypass or electronic spark timing (est) circuit
- 66 - pressure sensor or circuit air conditioning
- 67 - nothing listed on gm trouble codes site, do you know what this is?
This is my brothers car, but he is very short on cash, any ideas what the issue is? What should we have fixed first?
41 & 42 first.
Code 41, Loss of cam signal.
The easiest test is to back-probe the Brown & Black wire at the ICM (Ignition Control Module) with the key-on while barring the engine SLOWLY.
Simple high to low signal from the Cam Sensor, The voltage will be high 'till the magnet on the cam gear passes the sensor.
1. First, OE ICM's produced 10 volts as a power supply to the Cam & Crank sensors it is not uncommon to see lower voltage on the signal wire. Flow charts say 10-11 volts, but most aftermarket Ignition (IGN) modules do not put out that much. Typical to see 5-7 volts in most cases.
2. Probe the Brown/White wire at the module. Roll the engine by hand and see if voltage toggles to 0 when the magnet passes the sensor.
3. If no change in voltage, then remove the sensor from the engine, and roll the engine around until the magnet is found on the cam gear. Check for it to be missing or damaged.
4. If OK with the sensor out and key on, run an alternate magnet past the sensor and see if the 6-7 volts is pulled to 0 volts. Sometimes the magnet is not damaged, but can be weak.
If no voltage is on the Brown/White wire, Check for voltage on the White/Black wire at the Cam Sensor connector, And ground at the Grey/Red wire at the Cam sensor.
Code 42, EST circuit.
1. Disconnect the Engine Control Module (ECM) and then turn the key back on.
2. Connect an ohmmeter to terminal G2, a White wire at the Grey ECM connector. The resistance to ground value should read less than 500 ohms.
3. With the ohmmeter still connected at terminal G2, connect a test light to Battery Positive (B+) and then probe terminal G7, a Tan/Black wire at the Grey connector. The ohmmeter value should have switched from under 500 to over 2000 ohms.
4. If this switching did not happen, check the White and Tan/Black wires for an open or short. If both wires are OK, the ignition module is faulty.
5. If it switches from under 500 to over 2000 ohms, the module and its wiring are OK, and the ECM is faulty.
Code 38, TCC brake switch error, Check for power on the Pink/Black at the brake switch, Check fuses if no power is found.
60's codes are HVAC, I'm guessing not relevant at this time.
