P0304 CYLINDER 4 MISFIRE IN THE EXPEDITION
Newark NJ
What is the FIRST thing I do for this???
Checking spark plug wire as we speak..
Swap spark plugs with another cylinder and see if you can trade wires with that cylinder too (switching at the coil as well) and unplug the battery for a little bit to clear the code. If the code comes back check and see if the check engine light misfire code switches to another cylinder. If it does it's either the spark plug or wire. If not it might be an injector.
I hear ya. Makes logical sense. But I cant even SEE the wires so this may need to be taken somewhere if it comes back..
Pull the plug also. It could be fouling. Consider getting rid of the "Expedition from h-ll"! LOL
Is it currently running? How many miles are on it? Has it ever had a tune up? Lot of questions involved in the diagnosis here. Below is a link to a brief description of some possibilities, but more information is needed to get an accurate prognosis.
http://engine-codes.com/p0304_ford.html
Hopefully it is something simple like a faulty coil pack or spark plug. Good luck, and keep us posted!
Be careful with plugs in this engine. Both the 4.6 and the 5.4 have very little thread in the cylinder head that engages the plug. Stripping the threads is common if the plugs have been in there for a while. You might want to take it somewhere before touching it, unless you're good with a helicoil....
Note: I was going to say, "you should have the wheels refinished and polished first..." But this problem coming up is precisely why you can't go spending $$ on un-needed cosmetic bull$#!+...
It's a coil. It is always a coil with a Modular. I've replaced most of mine. It does NOT have plug wires. It is coil on plug. The bolt is 8mm and you risk dropping the bolt down into the intake area, so be careful when replacing it.
That is not a realistic course of action with this engine. #4 plug (like the rest of them) is 6" down a tube, but this one in particular, being the back plug in the passenger side requires multiple extensions and a universal to get out. It has the rear heat and A/C lines running directly above it; it is the absolute worst plug in the engine and this coil goes bad due to having the coolant lines running directly over top of it and the A/C lines so it gets bathed in heat and condensation. Not one of Ford's brighter plumbing ideas.
Not always-I had a similar problem with the E-250 4.6 2V in my sig-dealer put a coil & plug in it, no improvement-but a double dose of Techron & a tankful of Shell V-Power combined fixed it, 11 months ago.
Ah, I see. My grandma's Trailblazer has the coil on plugs too and it had one die. We swapped it with another cylinder and the code followed. Although these are extremely easy to get too.
I have admittedly limited experience with these engines, but from what I've seen, a coil is by far the most likely cause.
If that plug really is a bear maybe some slackjawed mechanic in the past replaced all 7 of the others and left this one alone.
You guys have poopy gas then, LOL! It has always been a coil for me
Originally Posted By: CHARLIEBRONSON21
Hopefully it doesn't shoot out. Be careful removing that plug.
That's the only one I've had shoot out, go figure, LOL!
Possible. IIRC, they are supposed to be replaced at 150,000Km (roughly 90,000 miles). I changed mine myself. Torqued them all and then six months later launched one. Also, another got loose by itself and had to be re-torqued (sounds like an exhaust leak). Been fine since (knock on wood).
That said, that coil failing is common due to what I mentioned earlier. So I would start with that. GHT does not have the tools or experience to change the plugs on this engine, I'm actually concerned about him changing the coil, particularly this one.
For some reason i thought the 97 4.6 had either COP or a wierd looking coil and plug wires?
I believe you are correct, the 4.6L had plug wires (likely a carry over from its use in the 'Vic) whilst the 5.4L had COP's. The OP's truck is a 5.4L, so it should be COP.
Also, I stated the wrong size earlier, it is 7mm on the COP's, not 8mm.
Not sure on what year the 4.6L went COP. Probably when they went PI.
Check the wiring harness going to the fuel injector. An intermittent connection will cause a misfire.
Do your research on spark plug removal; don't let this engine baptize on proper plug removal technique
