garageman402
$100 Site Donor 2024
I'm thinking about putting the "Torque Star" Grand Prix GTP wheels on my Montana minivan. The stock wheels are steel with Grand Prix wheel covers, and are 15", 5x115 bolt pattern. Both are FWD, so I'm assuming the offset should not be an issue. Some of these vans came stock with 16" alloy wheels, just not the same style as the GTP wheels.
My question concerns structural strength. Would the Montana be too heavy for these wheels? If the GP has the V6, the front axle would be comparable in weight, the rear may be a little heavier, tho.
This van came stock with the GP "look", so this wouldn't be too far removed style-wise, and I think the 16x6.5 wheels would add a little handling improvement over the stock 15x6 wheels. The tire circumference would be within 3/4"(.22" diameter), so the clearance and speedo error should not be an issue. A 225/60x16 would put an extra 10mm of tread on the road as opposed to the stock 215/70x15.
Any thoughts?
Any thoughts?
