Originally Posted By: dlundblad
Originally Posted By: friendly_jacek
how can you say that when no UOA are available on maxlife?
I got one!
Iron (Fe)245
Chromium (Cr) Lead (Pb)35
Copper (Cu)22
Tin (Sn)1
Aluminum (Al)5
Nickel (Ni) Silver (Ag) Titanium (Ti) Vanadium (V) Silicon (Si)11
Sodium (Na)8
Potassium (K)3
Magnesium (Mg)3
Calcium (Ca)221
Barium (Ba) Phosphorus (P)521
Zinc (Zn)19
Molybdenum (Mo) Boron (B)238
Antimony (Sb)
where did you find those numbers? the P/Ca/B numbers are roughly consistent with what i remember from VOA.
it's weird that Fe is higher than AL. I'm used to see the opposite in AT.
how about viscosity, miles, and application?
Edit:
never mind I remember now, you are the guy who has tranny failure with maxlife!
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2880013
He is the reason I am scared of doing ATF drain and fills. Lol.
His transmission threw a hard part which is a common failure item in his specific transmission and blamed it on the fluid.
Surely if Maxlife was so bad then every other person running it would have there failures also.
Can we ban this guy yet?
