Fluid extractor on the cheap?
I meant the pump doesn't run in park.. Not neutral. I knew this.. duh.
Either way, I wont try it though. Thank you for the clarification.
Well, the amsoil pump came in today....the salesman said it was made here. Looks pretty good, but not exactly as pictured, just different metal color......anyway, it says its ok for anything but brake fluid and will get an entire pint per pump.
This is my second Amsoil order, about ten years ago i got trans and diff fluid for,a truck. Im more of a Redline guy.
I've been using that 'Amzoil' goody for about 30 years-think it may be a 'Plews' product. It does fine for trans/diff-never considered for engine oil=gravity for me!
