I changed the oil in the Uplander in my sig today. Out went Mobil 1 High Mileage 5w30 and in went Valvoline MaxLife 5w30 synthetic blend. The filter stayed on from the previous oil change (Fram Ultra). Anyway I used my new fluid extractor, I pumped out 4 quarts (which is the capacity) and put 4.5 quarts back in because thats what it usually takes to bring it to the full mark. I checked the level and it wasn't registering on the dipstick. I checked multiple times and nothing! I have never had this happen before, so I added a little more oil to see if it would register but still nothing. Knowing that oil HAD to be in there I drove the van and rechecked the level, still not showing anything on the dipstick other than some residual oil from sliding the stick in and out of the dipstick tube. I say all that to say this....I pumped out 4 quarts (which is the oil capacity) put in 4.5 (not thinking about the filter that I DID NOT change, which probably holds half a quart). This leaves me a quart over filled, I dont know what it is about this oil, but its not letting me get an accurate reading, but will 1 quart over filled cause any damage? I saw a couple bubbles on the dipstick but no frothing or anything out of the ordinary.
