JHZR2
Staff member
I got a killer deal in a slightly damaged tool chest workbench at Home Depot. I think they must have been leading old stock from a warehouse because there were a few items with Black Friday sale markings on them.
Anyway,mit was so cheap I had to pick it up. 52", 10 drawer locking chest with a bamboo top.
The issue? One corner is bent. Not so bent that the wheel is off the ground, but bent enough that there is noticeable misalignment in the metal on the bottom. I can't get the unit to tilt side to side like you would on an item where one leg is shorter than the other three.
So, should I try to bend it back, or will that cause more issues than it helps?
If I try,mwhats the best way? I was thinking a piece of wood, hit with a BFH? Or should I just smack with a rubber mallet?
Thanks!
Thanks!
