MolaKule
Staff member
This polymer base oil has a low traction coefficient, good solubility with GroupI-IV oils, good seal compatibility, high viscosity indices (to over 200), low friction coefficient, low deposits, fast air release, and are less hydroscopic than esters.
The starting material can be 1,2-butylene oxide.
This base oil has recently found application for use in Wind Turbine lubrication.
What is this base oil?
Guidelines for the Question of the Day:
1. No Piston Cup Lapel Pin will be awarded to the same person within 14 days of a previous award.
2. Please respond with a complete sentence or explanation.
3. Please do not post links. If a question arises as to the need for clarification, then sources and links may be requested.
4. Please, no off topic posts.
