Additive to convert GTX 10W30 into a high mileage
BC, Canada
Have a couple of jugs Castrol GTX 10W30 I purchased cheap on sale.
Any recommendations for an additive to essentially make this a high mileage equivalent?
Thanks in advance!
You could always just buy 1 quart of HM Castrol GTX and blend it together with a few quarts of the conventional stuff... Just a thought.
Like your idea, thanks!
Thanks in advance!
Fram High Mileage Oil Filter is a great option. I once looked at the patent Fram has for this, and its the real thing. Time-release additives are slowly generated from a gel pac inside. Besides, a Fram oil filter is pretty good as well, having glass fibers mixed in with the usual paper filter area, and it is around 95% ISO 4548-12 at 20 microns.
http://www.fram.com/oil-filters/fram-high-mileage-oil-filter.aspx
Originally Posted By: 901Memphis
Originally Posted By: Clevy
Liqui-moly motor oil saver.
This is the best answer honestly.
Ok, where can I buy this in Canada?
I'm waiting for this answer too but seeing you are from BC i did find this place.
www.hopefungautoparts.com
Thanks for your efforts Oily, I'm closer to Alberta so I'll search for a dealer over there.
