Originally Posted By: wemay
I've always thought that if both oils being mixed were SN, the finished product would still be SN. The base stocks portion being either diluted (from the syn point of view) or enhanced (from the conventional side). If the additives pkg is similar, who knows how much change the mix may cause. Or, how significant.
I would also agree that mixing is just fine.
wemay, even 'though the API base oil interchange rules have been used here to erroneously justify blending in general, and a fabled mix in particular, it's not that simple.
If you were to create "wemay blend", a 50:50 mix of dino and synthetic, you could not claim that it met SN, without further testing.
Bear in mind that these guidelines and requirements are for changing basestocks with a single additive package, not mixing two additive packages together as well...consensus on this thread is that the additive packages are so similar it's moot (I disagree, but will hold the ruse for the rest of the discussion and limit it to basestock changes, 50:50 blend).
Consider the blend either a GrII with half replaced with GrIII, or a GrIII with half replaced with a GrII...semantics, but it's applicable even when changing basestocks within GrIII and GrIV themselves...GrV, needs testing nearly every time.
wemay blend would have to undergo the following testing before wemay could claim even SN.
* Sequence III
* Sequence IVA (not required if blend is same or higher viscosity, required if one of the oils is GrIV)
* Sequence VE/VG (required if one of the oils is GrIV)
* Sequence VIA/VIB
* Sequence VID (Not required if HTHS is less than either original, required otherwise) - LOL, See IVA above.
* Sequence VIII required only if the synthetic is GrIV
The sheet has some worked examples for comparison.
So the blending proponents who state that "of course" "the blend" is an SN, can't claim that with certainty, as the API doesn't even recognise it as such.
