Originally Posted By: RamFan
This thought just came to mind so bare with me. Is it better to allow your car to get to empty before filling up or to fill it up at the 1/4 to 1/2 a tank marks?
Letting gas get too low can cause issues with fuel pumps, however any contaminants that may be in the fuel will be run through the system in their totality.
On the flip side, filling up with a quarter to half a tank left is better for the fuel pump but may lead to increased contamination levels of gas in the tank, if the contaminants float on the gas surface.
What are your thoughts?
Contrary to popular belief its not running the tank low that might cause a fuel pump issue, its running out of gas as the pump is lubricated and cooled by fuel going through it, not sitting in it.
But you could run a Toyota out of fuel daily and no problem, run an early GM out of fuel once and you may need a new fuel pump.
The fuel pump typically has a "sock" on its intake to filter out anything that might damage the fuel pump.
You would be surprised how pristine a fuel tank looks on the inside.
