Originally Posted By: mjoekingz28
You were right AMR7, 3/8ths Allen. Got my Bondhus today and it lacked the 3/8" key, so i chanced it and held a 5 second grunt on the HF one I bad mouthed earlier. First time using it and it did well, 3/8" was the largest SAE in the set.
Never really understood the overtorquing of fill plugs, thing had red/orange loctite on it, or it could be the stuff they put on engine temp sensors since the threads were the same color on them.
I called Magna and they have no technical division, the lady was a bit befuddled when i asked for transmission fluid recommendations.
Stuck my finger in the check plug and out came a pretty clear gear oil smelling fluid, so I dont know if the PO put in gear oil OR that is factory fill and is still at a perfect level at 165,000 miles?
Thanks to all who contributed!!!!
Originally Posted By: ArrestMeRedZ
At 50k, my fluid looked new, and the level might never change if it doesn't leak. Your guess is as good as mine if it has been changed.
If you use something other than Syntorq LT, keep us informed how it does. I want to hear how it's holding up at 400k miles.
I had one apart at somewhere north of 150k to repair the 5th gear retaining nut, and again to repair a worn out 2nd gear syncro. I can say that while the oil that was in there "looked" good and relatively clean, there was a very light gray coating on everything in the trans and the oil had a light gray color to it. I'm assuming it was wear metal and syncro material.
The new (OEM) oil was about as clear as tap water.
