From what I've read from Subaru techs, the problem with FB20s that consume oil is the piston rings. Unfortunately, if you piston rings are really toast then going to a heavier grade oil probably won't significantly reduce blow-by.
When I was looking for a vehicle, I bypassed Subaru due to the consumption issues and went with my Toyota. I know a good portion of the FB25 and FB20 engines don't have an issue, but I didn't feel like rolling the dice.
