Quote:
If cost is not a factor, then why are you not using a dedicated firearm lube? Sure - they are more costly per oz. But you just said cost does not matter.
I meant cost of a motor oil is not a factor. FireClean is $17 for 2oz. That's pretty expensive. But some guys like Cujet above, find that Mobil 1 works way better than Rem Oil.
I have a few dedicated gun oils but just wanted to know if I did decide to give motor oil a try, which one is best. After all, if it's equal or better, a lifetime supply is $8.00.
