Originally Posted By: meep
Originally Posted By: supton
Originally Posted By: doublebase
I went to a dealer and the parts guy warned me to be careful changing the fluid and to make sure I got the level right because he's seen some go bad in as little as 700 miles, because of fluid level.
Yah, 'cuz the parts guy would never upsell anyone, nor try to convince a customer that they should let the well-trained
monkeys technicians out back do the work for them.
I changed the trans oil on my truck, and while it's a pain it's not rocket science. Get trans to temp, pull a plug. Add as necessary. I'd much rather a dipstick, which would then double as a fill tube; but since the diffs are essentially the same (minus the temperature bit) I'm not sure how much I ought to hate on it.
@supton, which of the two plugs is the drain, and which is the get-the-level-right plug? I'd hate to pull the wrong one.
-m
I think you have an a750. Look through this doc
http://www.toyotatundraforum.com/pdf/A750E.pdf
and I think the difference in plugs will be apparent.
The fill plug is up off the pan, the check level is higher on the pan in a recessed are iirc. Drain plug is lowest.
