I used to always change the drain plug gasket after an ATF drain-and-fill, but the past 3 or 4 years I kept re-using the same metal drain plug gasket, and that was a mistake. After I did the ATF drain-n-fill in late August this year (maybe August 28th), I noticed the ATF was dripping out slowly: maybe a couple drops an hour?
So I placed a long and wide but very short drain collecting pan under the Camry when parked in the garage to see how much would drip out over time, so I'd know how much new ATF I'd have to add over time. The Camry's ATF dip stick is really hard to read accurately (it's hard to tell how high up or low the oil reaches on that poorly designed dip stick).
Today I poured the ATF that dripped onto the garage's long, wide drain pan into a measuring cup and saw about 4.5 ounces of oil in the cup. I estimate another 1 or 1.5 ounces was still left on the long pan, so I guess roughly 6 ounces dripped out in the 3 months and 1 week since August 28, when I did the ATF dnf.
So I added into the refill hole about 6 ounces of ATF Type T-IV. Wish I had used a new drain plug gasket in August when I did the dnf.
