Fordtrucktexan
Thread starter
Originally Posted By: HerrStig
What's the cross section of an "SS" hose look like. The stainless braid does NOT contain the fluid. Some "SS" hoses use a teflon liner , others just a plain rubber liner just like a 'SS' washer hose. What does the braid do... raises the bursting pressure.
You raise a valid point. I had not considered the fact that the SS hose is still a rubber hose (or teflon) at it's core.
After reading the opinions expressed here and other forums, as well as actual product reviews, I've come to the conclusion that, for all intents and purposes, buying some new OEM hoses will suffice for my driving needs.
Originally Posted By: zzyzzx
Exactly how does a deteriorating flexible brake hose ruin a brake caliper?
The hose loses it's structure over time and doesn't allow the fluid pressure to return as it should, causing the caliper to repeatedly 'stick' until it fails. All but one of my calipers (driver rear) have been replaced due to dragging or sticking at one time or another.
Originally Posted By: CT8
How often do you change your brake fluid?
I haven't changed it since I bought the truck in Sept. 2012.
