MolaKule
Staff member
Originally Posted By: GMorg
My point is still being missed. The custom tune run was at 1:49, before ALL listed stock runs on RP. NO runs are listed for RP before adjustments. My question related to whether it is even possible to make adjustments between Stock oil and RP oil and conclude that RP was tested under the same conditions.
I have seen several posters say that RP oil was tested under the same conditions at stock oil while ignoring that the data provided shows that the Stage 1 tune was done before the stock tune for the RP runs. In the text, the link suggests a sequence of events that do not seem to be compatible with the data that they show. That is what troubles me.
I don't expect a statistical power test, or even a great experimental design for this type of data. That part doesn't bother me. However, to imply one thing having done something else implies that either the author of the link did not understand what was done or that the the author is not being truthful -- that bothers me.
I was hoping that someone would read the time stamps and tell me where I am wrong. Or, someone would explain that there are no stored data on this vehicle and that it is possible to change tunings back and forth with repeatability. I have not heard either.
I agree, the sequence of events and background data seem lacking.
What i was saying was the Dyno data itself appears to be as tested.
In terms of friction modification additives and base oil mix, I can modify both to get that percentage of HP rather easily. Now I can also tell you that the wear data will be worse.
