Quick Update
I remembered I had a bottle in the Jeep, so I added a little Marvel Mystery Oil to the fuel when I gassed up yesterday. Per the instructions, "Marvel recommends using 4oz of MMO for every 10 gallons of gasoline."
Tank had about 4 gallons left, a few notches above empty.
Jeep has a 23 gal tank. I added about 6 oz., so I'd have some left. I think it's helping in that the engine idle seems quieter, smoother idle, and it starts much smoother/a little quicker.
MMO FAQ:
http://www.marvelmysteryoil.com/index.php/site/faq/
Info copy/pasted from here:
http://www.marvelmysteryoil.com/index.php/site/mmo/
I've noticed this ticking sound for a while, so maybe next oil change I'll throw in another MMO into the oil.
"..added to engine oil, Marvel reduces/prevents valve sticking/clatter by breaking down deposits of carbon/sludge.
..valve sticking can be identified by a "ticking" sound from the engine when running.
It may be in my head, but since adding it to the fuel yesterday, the ticking seems quieter when idling. However, now that I think about it, I should probably check the belts, since IIRC, they can make slight "slapping/clicking" sounds.
It seems to help cold starting, though we haven't had anything below 12 degrees F for a week yet, at least in the Twin Cities, MN.
MMO's supposed to help easier cold weather starting with its extremely low pour point of (-65) Fahrenheit and ability to eliminate oil's tendency to congeal at low temperatures."
I've learned to take any benefits on any product w/ at least a grain of salt. But I do think MMO/Seafoam is probably better than most other additives (not to start an "additive war").
Question
Would MMO (or Seafoamn) in the fuel, or in the oil, clean the IAC, or any of the throttle control parts?
Thanks.
