Quote:
Can I use diesel engine oil in my petrol engine?
This is an awkward question to answer. Diesel engines run much higher compression ratios than petrol engines and they run a lot hotter, so the oil is formulated to deal with this. Plus they produce a lot more dirt in terms of combustion by-products. Diesel-rated oils typically have more detergents in them to deal with this (see Using Diesel oil for flushing above). It's not unheard of for diesel oils to clean a petrol engine so well that it loses compression.
http://www.carbibles.com/engineoil_bible_pg2.html
