Thought i was ging to show you what can happen to an engine if the airfilter is never replaced and it sits in a dusty enviroment.
The pics comes from a CAT engine that is used to power a generator at a quarry and its used to power the rockchrusher.
The pistons and cylinderlinings are ok but the valves are a different story.
This one is not that bad:
But this is way worse:
The valve seat on the worst valve is so damaged that its not repairable and we have to replace the whole head.
The engine sits in a container but when its running the doors to it are open to let the fan draw air through the radiator, the airfilter sits on top of the engine inside the container but since the fan draw in air it also get all of the dust from the rockchrusher.
You can probably guess how it looks inside it after a day and all that dust blocks the airfilter, intercooler and radiator making it working harder to get air and whith a blocked intercooler and radiator its running hotter then designed and then things start to go bad real quick.
