10 UOAs, various amsoil oils, 2002 3.8 windstar
pb
stl
2002 ford windstar 3.8L V6, all tested through oai
Code:
OIL ATM 10w30 ATM 10W30 ATM 10W30 ATM 10W30 ATM 10W30 ASL 5W30 ASL 5W30 TSO 0W30 TSO 0W30 TSO 0W30
MILES(TIME IN USE) 7650(29 MONTHS) 17.4k(42 MONTHS)14K 23K 16.3K 15.2K 16.6K 24.6K 4345 19.7K
O&F CHANGED Y Y N Y Y Y Y Y N N
MILES 150K 142K 139K 125K 102K 85.8K 69K 52.5K 32K 22.8K
MAKEUP OIL 0 0 0 0 0 0 0 0 0 0
SAMPLE TAKEN 23-OCT-13 30-MAR-11 26-DEC-08 18-OCT-07 29-JUN-06 26-OCT-05 17-FEB-05 21-JUN-04 4-JUL-03 26-DEC-02
IRON 9 33 19 25 22 34 37 76 28 109
CHROMIUM 0 0 0 1 0 1 2 3 0 3
NICKEL 0 1 0 0 0 0 0 0 0 0
ALUMINUM 3 4 3 13 10 7 10 12 5 12
COPPER 12 13 5 19 16 30 21 46 20 42
LEAD 3 18 11 14 8 15 13 22 5 21
TIN 0 0 1 0 0 0 0 0 0 0
CADMIUM 0 0 0
SILVER 0 0 0 0 0 0 0 0 0 0
VANADIUM 0 0 0 0 0 0 0 0 0 0
SILICON 42 63 22 29 22 19 19 65 50 129
SODIUM 4 12 9 0 0 23 9 15 8 21
POTASSIUM 0 0 0 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 0 0 0
MOLYBDENUM 54 60 50 57 8 3 5 4 2 11
ANTIMONY 1 1 0
MANGANESE 0 0 0
LITHIUM 0 0 0
BORON 196 103 105 64 35 21 15 17 72 4
MAGNESIUM 16 31 24 139 854 843 781 710 906 311
CALCIUM 3479 3481 3041 3898 2687 2016 1870 1916 2704 2768
BARIUM 0 0 0 0 0 0 0 0 0 5
PHOSPHOROUS 679 698 613 792 1106 1046 1005 912 1132 1089
ZINC 808 882 752 949 1354 1444 1279 1338 1244 1218
WATER 0 0 0 0 0 0 0 0 0 0
cSt @ 212ºF 11.2 12.8 12.8 19.32 15.68 16.14 17.01 22.05 12.23 17.17
FUEL 0 0 0 0 0 0 0 0 0 0
TBN 6.05 2.29 2.87 2.22 3.17 3.66 3.65 3.69 5.42 3.37
OXIDATION 50 64 43 31 21 28 11 13 3 4
NITRATION 11 35 26 34 35 1 10 12 2 4
Originally Posted By: friendly_jacek
I don't understand all that thickening out of grade. I thought those were 25,000 mile oils?
it must be my driving or the engine, right?
Originally Posted By: Burt
You are going 15 to 25k miles between changes and not adding any oil? Hmmm...
i checked all my notes and couldn't find it documented, but i'm fairly certain i was adding make up oil until i got to the 10w30. of note of your '98, the predecessor to my vans was a '98. i could post those uoas for you. it suffered an engine failure @ 154k due to a head gasket. i miss that van.
yeah, that first oil change was a 60 weight oil being taken out of there.
Guess thats still within the realm of the "usable" since BMW M engines use 60. Wow thats double the KV100 of a 30 weight.
I'm betting that the transmission goes on mine before the head gasket. I drain and fill the transmission every 15,000 miles or so. I've done of couple of UOA's, but nothing notable.
Amsoil, for years, was known to thicken up significantly on long intervals. Didn't impact wear, but the oil thickened.
I would not to long intervals on an engine known for HG issues. Just too much risk!
Im doing 15 000 miles oci's on both my Sonatas.
I did take many pictures with valve cover off.
So from now on will do only one oil change per year.
I'm very happy with Amsoil Signeture motor oil.
I remember that part about Amsoil thickening out of grade from the neptune spacebears study.
but it must have bad effects on MPG.
on the other hand, I found a recent 25,000 mile Amsoil UOA from prius where 0W30 thinned out of grade to 9 cst. What gives?
