Shelf life of opened fluids
How long can these fluids typically last once they've been opened?
-Motor oil
-ATF
-Coolant
-PS fluid
-Brake fluid
Brake fluid shouldn't be stored for long but I've used 2 yr old opened bottles of the other fluids for top offs w/out issue. My garage goes through regular seasonal temperature fluctuations but I make sure the bottle caps are on nice and tight.
Brake fluid is hydroscopic, meaning it absorbs water. The other fluids generally don't have this problem.
refrigerated, frozen, room temp???
It's not hydroscopic when capped tightly, as it needs access to moisture in order to absorb it. It'll be good for years if capped tightly, just like the brake fluid in your vehicles brake system right now. It doesn't go bad in months, so neither would fluid in a capped bottle. Now, if left without a cap or a loose cap, then it will be bad in short order.
