OVERKILL
$100 Site Donor 2021
Originally Posted By: sayjac
MaxLife has added Mercon LV to the front label in addition to Dex/Merc. Shown in link.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3589573/Has_MaxLife_ATF_changed_its_la
Yeah, but it is a high mileage fluid "recommended for":
Originally Posted By: Ashland
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
This transmission was one that was originally NOT back-spec'd to Mercon V until they changed the formula. And Mercon and Mercon LV, as well as SP (which this fluid is universally recommended for) are all very different fluids. As is ATF+4 (Mercedes NAG-1 shown in the above list).
This is one of those "jack of all trades, master of none" fluids that, if the transmission pukes, because it is "high mileage" there's no onus on Ashland because it was already "old".
Example, the Mobil Dex/Merc fluid has a 100C visc of 7.2cSt, this fluid is 5.9. Significantly thinner. Mobil 1 synthetic ATF, also a Dex/Merc fluid, is 7.4cSt. Again, heavier. This may not be an issue in a GM tranny, as they back-spec'd DEX-VI for DEXRON apps, and it is a ~5.8cSt fluid like this Maxlife product, but Mercon V is a 7.4cSt fluid, which is the alternative fluid for this gearbox.
I would not use this fluid in this transmission.
