Originally Posted By: meep
I have had decent/mixed results with the HID projectors sold by theretrofitsource.com. nice product and good service. You would want a hi/low assembly with a solenoid that moves the shutter for high beam.
In my experience even their products were weak on distance and too hot on nearfield distribution, and just as annoying, the color of even the non-blue bulbs offerings were too blue-- halogen light was easier on my eyes for long drives. I eventually went back to halogens in the mains. The improper distribution was a real problem on the highway -- despite the greater output, the bright foreground really didn't help distance vision and started to fatigue on longer drives. I wanted to like it. But I just couldn't.
The fog lamps, however, were a different story. I continue to use the projectors and have a yellow filter over the lenses. It is a different set of the same model projector. I don't know if the distribution is better or if the proj's were just designed to be closer to the ground. Cutting the blue out of the light, they are phenominal; best fogs I've owned, with good output, spread, sharp upper cutoff, and no eye fatigue from blue spectrum. distribution flaws are probably not as noticeable down there, either, as they aren't supposed to reach far out; they do their job down low and closer in.
Which projectors did you use? I've done retrofits on 4 cars now and they all have been fine. TSX projectors in my civic, RX-AFS in my mother's odyssey, and s2000 projectors in my sisters TC and Elantra. All have been perfect! I can say that the morimoto bulbs are not very good though. At the very least get some Osram or Philips bulbs. None of the aftermarket stuff is worth it, I always end up with some janky looking blue color and poor light distribution. Buy once cry once IMO.
