Originally Posted By: deven
RP is at it again with their HP claims. Wasnt there a lawsuit by BP that said they couldn't claim HP gains anymore? LOL.
Tech Tests HPS in Subie
deven;
NO reason RP can't claim their oil added HP in this specific case because it did. This isn't a generic marketing "blanket" claim. Also, RP voluntarily stopped making those claims. BP didn't actually sue them in court but rather it was a marketing/advertising board that heard it. Some branch of the Better Business Bureau. They basically told RP they should modify or stop making the claims like they were and RP agreed. RP was not legally bound to do so however. Just an FYI for you.
I have to say, seeing as you are an RP user, I am surprised you brought this up the way you did.
The RP detractors on this site always poo-poo these RP dyno tests claiming that it is rigged or they don't use a fair comparison oil( i.e. 5W20 RP vs 10W40 or 20W50 for the other ). Basically that the entire test is flawed or rigged somehow.
Well, this seems to me to have been a very fair comparison test and it is exactly the kind of test the naysayers always say they want to see run if the oil mfg is going to make claims of HP gains.
We have multiple dyno runs of each oil done on the same day, on the same machine, so we can rule out weather impact and any differences between the dyno machines used. They also used NEW Subaru 5W30 synthetic oil vs. NEW RP HPS 5W30. So the vehicle was tested using fresh oil in each brand plus the same weight was used so there was no funny business with different weights being used.
I am curious just what else people expect RP to do in providing data that the RP oil provided a HP/FTLBS increase? I would say they made a good faith effort to be as fair as possible in the test. The RP oil had no advantage over the Subaru oil. Both were synthetics, both started out as fresh OC's, both were the same weight, and the same dyno was used to do the runs which as I read it were all done on the same day.
I guess I fail to see how this is anything but legit? On that day, in that vehicle, the RP oil did in fact provide a power gain over the Subaru oil. Doesn't mean it always will but it did that day.
