garageman402
$100 Site Donor 2024
I've read the threads about how a bottle of Techron really cleans up a fuel system, saw the experiment with the bore scope, and the debate over if Chevron gas is really worth the extra 45c per gallon.
Does anyone know the concentration of Techron in the gas Chevron (and Texaco) sells?
I've heard from tanker truck drivers that Chevron is the most picky about the additives. If they are loading up, and the additive package gets botched, they will dump the whole load and start over. The driver who gets paid by the load doesn't appreciate this. By dumping the load, it means it goes to the off brand stations.
A 20oz bottle of Techron concentrate available from Amazon is $12.62, not counting tax, and it treats 20 gallons. That comes out to 63c per gallon. If you include the 9% tax they add for CA. it's 69c per gallon. So if the pump gas from Chevron is treated at the same rate, then yes, it is worth the extra 45c per gallon.
How about different grades of Chevron? Does the Supreme have more Techron? Shell claims it's V-Power has 5 times the additive of it's Regular gasoline. I think I've heard Chevron Supreme has 2 times the Techron than it's Regular, but can't confirm that.
Thanks for any insight......
