I drove a livery Town Car with 580,000 miles...original engine, even the original AC compressor, alternator, and radiator. (Replacements were dated by the mechanic, these were not.) The AC blew cold, it tracked perfectly on the highway, all the electronics worked, the air suspension worked perfectly. Aside from valve seals around 200k, they had never been inside the engine. Serious question: could your Jetta manage another 275k in any way short of a full teardown and rebuild?
Note that 350-400k from a Panther car was the rule at that company, not the exception.
Good question; I'm not sure. Will your Panther last 20 years of salty NH winters? That is how long it'd take for me to hit 500-600k. Also, you don't state how many transmissions it went through? Seems conventional wisdom indicates 150k on an automatic; are you beating by some significant factor?
As pointed out, fuel cost is not insignificant. Since my car is a depreciating asset that doesn't make me money, fuel cost vs replacement cost (depreciation?) also plays into it.
I honestly don't know. My cheapest option is to keep running my Jetta and fixing whatever breaks. That much I know. Every other option costs money, although keeping the Jetta may cost just as much (heater core? various body panels? etc).
Third 4R70W, AFAIK...the shop they use is very, very good and they get ~220-230K on rebuilds. (The same shop rebuilt the 4L60E in my first Caprice and I was pretty impressed.)
Considering the company is still running pre-1998 Vics, I would say yes, they will last 20 years. (The company is in Massachusetts.) All cars are thoroughly rustproofed upon purchase & have been since the mid-90's.
Is your Jetta up for a run to Rhode Island? If so...hit Auto Rust Technicians in Cranston. Superb work, fast turnaround, very good prices. If Jettas have common rust spots, he probably has pre-made repair panels. Also: bring your Tundra, and he can do a full undercoating to prevent a replay of the Jetta scenario.
So at least $4k in repairs to go 500k (2transmissions). I spent about $4k at the 250k mark on clutch and turbo, and those should go 250k or more. (My mechanic at the time had 500k on his with similar repairs. I think he is at 550k now.) 1.9's are pretty durable. I turned the wick up on mine with the turbo, 40% more power, and it's shouldered that pretty well for the last 50k.
A rebuilt Panther 4R70W is ~$1K installed. Even the built 4L60E in my Caprice (including a rear main seal, flexplate, and adding a cooler) was $1450 (same shop).
Quote:
My vehicles rust from the top down. Rock chips are a bear. I've started oil coating as I know my Toyotas won't last otherwise--VW has some great rustproofing. Thick layers of zinc, lots of caulk in seems, wax filled cavities. Well, on the MkIV that is--the prior MkIII had serious rust problems. My Toyotas chip paint if you look at them funny.
RI is a long drive (I've actually never been there!). I keep trying to justify getting a flat bed trailer but haven't been able to. Dropping a car off and paying a few hundred dollars in vehicle rental is kinda un appealing, thus the flat bed desire. Making my wife drive shotgun for vehicle repairs? For a vehicle she hates?
There's actually an Enterprise next door. What about a one-way rental, get the car there and return it in NH?
Quote:
My Jetta probably needs $3k in body repairs if I had to guess. Two fenders, one door, one hatch, windshield, rockers. Repaint. Throw in all the other niggling issues and it's clearly not worth it.
At this point, undercoating the Tundra might be more important.
