Originally Posted By: Bumble_guy
Anybody use a scangauge 2 , and do you like it, I just got one for my motorhome with a ford v 10 for transmission temp and fuel mileage ,any tips thanks
I have two, one in the work truck and use it to monitor trans temp and other things. If it's below freezing, the trans temp will give goofy readings. The fuel level never has read above 97% either, other vehicles it would go to 99. It's depressing seeing the fuel usage in the V10.
I bought another to use in the Accord to maximize economy.
Once you have it set up with a couple fill ups, it's a very accurate trip meter. I don't have range anxiety after the fuel light comes on because I can see how much fuel is actually left, and the range.
Very useful tool and better than the factory trip meters.
