Originally Posted By: sicko
You should be able to, but follow your OLM while you're under the warranty period.
Does your vehicle specify synthetic oil, or is the OLM set for conventional oil? If you have an OLM, follow it, then do a UOA on the oil you drain out of it and see if can handle going longer.
That was the first year for dexos1 requirements, so the OLM you'd think is different (longer oci's) that way compared to the model year before.
