I have a slide hammer with a strange jaw clamp device, and a C-clamp press to install the new bearings. I have no idea how to get this done with this type of slide hammer. Can someone please help?
THE TOOLS
DRIVER SIDE SPINDLE AND HUB
With seal. Note missing inner wheel bearing race. It seems to be still stuck on the hub, as you can see in the photo.
PASSENGER SIDE SPINDLE AND HUB
Still intact, but I need to take this one apart to replace the bearing as well.
SEALS
Are these the same on both sides of each hub? I only bought two, but it appears I’ll need two more, as well as the seals for the differential. Please point me at the correct parts.
THE TOOLS
SEALS
