Originally Posted By: zpinch
I searched and looked around, it sounds like the cooler IS built into the radiator, internally, however. If that is the case, then there will be lines feeding that like you said. I will check it out when I get the chance. Thanks.
Your transmission will have one fluid outflow line (to the radiator) and one fluid inflow line (from the radiator).
