Im so upset at myself, I cant believe i made a stupid mistake.
well I remove the old wheel bearing on 02 Honda Accord
when I took the old bearing off part of the bearing was stuck on the axle I guess you call it spindle or axle.. So I just chizzel it off.. no big deal.
I put on new hub assembly and torc to 139lbs and I said [censored], I forgot to put back on the brake dust shield..
It was dirty and i cleaned it and pained it.
sooooooooo
i remove the axel nut.
then i pull off the hub assembly
guess what????
when it came off it did the same thing the 1st one did.
part of it was on the axle / spindle, but it was not stuck...
So put brake dust shield back on and put the hub assembly on even though part was stuck,
** I could see the grease and ball bearing inside the assembly just like i could the old one i remove but on the new ** However the old one was all messed up **
So i put it back on put it on back to specs 139 pounds of torc ** the new one **
I talked the ppl at part store they said if not making noise it might be okay
another guy tried to scare me and said OHH the wheel is going to fall of while your driving.
this rear remember?
what do you guys think?
Did I explain his well???
am I safe?
sooooooooo
guess what????
this rear remember?
am I safe?
