There's been a vibration in our CR-V ever since I've owned it (which has been for about 50k of its near-100k miles). It's probably been there since new. You can feel it start to flutter at about 60 mph, it's pretty noticeable at 63-67 mph, and it's beginning to flutter back out by 68-70 mph. You can feel it in the seat/floor, and it doesn't matter how the tires are rotated...it's not a steering wheel vibration, but sort of a "whole vehicle" flutter. The vibration *sometimes* seems to come and go...like it's not completely consistent. There's always some sort of a flutter or vibe in this speed range, but it seems to be worse or better depending on some variable(s) that I can't put my finger on.
I've told myself a story about it ever since we owned it. It had a set of tires that was at least half worn when we bought it, so I assumed it was tires. Then with the second set of tires that I installed, the vibration was still there, and I probably assumed it was the tires. I had Sears re-balance those at least once, but to no avail. Now I've had a new set of tires installed and the vibration is still there. So I'm pretty sure that it's in the vehicle.
This is an AWD CR-V. Last night, I rotated the propeller shaft 180 degrees relative to the rear differential unit. I'm pretty sure the vibration got a bit worse, so I think I'm on the right track. I then put two hose clamps around the driveshaft, to add some weight, and now I get a similar vibe at about 58-60 mph. So again, I think I'm on the right track. My next plan is to completely remove the propeller shaft and see if it goes away. This AWD system is both mechanical and reactive, so removing the prop shaft essentially turns it into a FWD vehicle.
Am I doing the right things here? Any tips on balancing the prop shaft if that does indeed appear to be the problem? (The center carrier bearing appears to be in great shape, as do the rear differential unit mounting bushes.)
