Originally Posted By: turtlevette
It's disappointing since this could have been a good discussion with more open minds.
executive summary
OP Look at this cool study.
reply Its garbage because the test doesn't exactly replicate an engine
reply Don't you know bigger oil suppliers are always better anyway
me Yea but its the best convenient test we have right now for consumers to do their own testing
reply If you like that test use pert plus in your engine
reply you are ignorant
reply we'll teach you for thinking differently
me Car guys are concerned with wear under extreme conditions
reply Just buy a better car. Please do not concern yourself with picking the best oil
turtlevette, that's not exactly how it went down.
Amsoil, 504Rat, and a number of others use a test procedure that's designed for gears, greases, and hydraulic oils to say that their lube is best...that's the garbage science.
Industry has found that the 4 ball wear test isn't even very good at correlating to what it's supposed to be representative of, as evidenced by
the statements (wider than this link) th...ive activation) But additive activation between steel surfaces means that you've lost the race regarding lubrication.
Regarding what happens when oil pressure drops ?
As I stated, rings and pistons have circulation regimes of tens of seconds...they'll outlive a second or so drop...
Bearings were the next direction ?
They aren't simulated by the 4 ball, as the 4 ball is steel/steel, not steel on soft metals...the soft metals are chosen to prevent galling/pick-up, and allow a layer of embedability which will push particles away from the journal.
If it's an issue in your race car, then now is the best time to be alive, as in the quest for economy (or lower CO2 depending on your Government's vernacular), engines are being pushed into boundary lubrication more and more frequently.
The new wear tests in the API classifications have been modified to include more boundary, and OTC lubricants are meeting the standards...set by the engine manufacturers.
When these manufacturers do testing to simulate wear in bearings, they don't do it with a 4 ball, they have a rig that nearly always looks like a bearing...with bearing metals.
Other discussions
Here
and
Here
And rather than coming up with an additive or oil recommendation, they are coming up with bearing materials better suited.
http://papers.sae.org/2011-36-0189/
http://www.mahle.com/mahle/en/news-and-p...-conditions.jsp
If you are having issues, I'd start with Mahle bearings coated for boundary, then adopt the Miyagi defence of "best not be there", and choose a lubricant (as I siggested earlier) that's thick enough to hang around a little longer when the pressure drops.
