Originally Posted By: raytseng
Do whatever you want. If you don't trust honda, you're never going to trust them anyway.
When your gas light goes on, that doesn't mean you suddenly have 0 gas in your car and your car stops.
But anywhere here's a manual for the 2015 accord where they say on p488:
For 5%:
The engine oil has almost reached
the end of its service life, and the
maintenance items should be
inspected and serviced as soon as
possible.
Notice it says "almost", not your car is going to die now.
Then for 0% it says: The engine oil life has passed.
It paraphrases exactly what I said. It doesn't make sense to present 5% which is supposed to be be interpreted as meaning 0%. If they wanted to give that message they'd just display 0% instead (when it's 5%).
You can check other manuals too for other honda products, they all break it down to 15%, 5%,and 0+miles, but the tables might be slightly different.
http://owners.honda.com/vehicles/warranty?year=2015&model=Accord-Sedan
http://techinfo.honda.com/rjanisis/pubs/OM/AH/A2A154DOM/enu/A2A154DOM.pdf
But anyway oil is not a step function. If you're getting very uptight that your oil suddenly turning bad on a specific number, your oil is already marginal when it was getting down low anyway. It's not cinderella at the ball.
No of course it doesn't turn bad instantly, but multiply this by 20 oil changes and this is how varnish/sludge build up happens. What's the point of extending an OCI by only 5% when oil is so cheap. I don't get you people.
No I don't trust Honda or any car brand. They're companies who want to make a profit, not your friend. You people don't realize how many recalls & technical disasters all the major manufacturers have had to deal with over the years.
Honda alone: Civic R18 engine block
cracking from 06-09, extended warranties for all vehicles.
4spd automatic transmission failures especially in the odyssey,
class action lawsuit resulting in compensation for all people who had to pay out of their pockets for repairs.
V6 engine excessive oil consumption in 08-13 models,
class action lawsuit resulting in extended warranty for 8 years.
Takata airbag recall: Honda didn't report 1729 incidents, and was
FINED $70 MILLION for lying.
This is just a partial list for Honda, google everything and see for yourself. All of these incidents happened to people who were just 'following the manual' like you. Every other car manufacturer out there has a similarly long list. And you still want to trust Honda's OLM even though they
ADMITTED upto 15% error rate in the calculation?
GM even had a recall because their OLM was letting the car run way too long between oil changes. The result? Worn out balance chains. Over
770k cars affected.
http://autoweek.com/article/car-news/gm-reprogram-some-oil-life-monitors
Do whatever you want, I'm just glad I'll never be buying a used car from you.
