- Joined
- Dec 28, 2011
- Messages
- 5,058
I've inherited a 07 Maxima with about 95k on the clock. I'd like to take my time and basically do all I can to start with a zero base. I've come up with the following:
Plugs (maybe coil overs as well)
Trans filter with (pan drop change only)
Belts (I believe 07 uses a timing chain; so no internal drive belt)
PWR steer bleed/fill
Brake fl bleed/fill
Rotors/Pads
Fuel Filter
PCV (internal?? Or externally accessible?)
Front Axles (I'n not sure here, are the Axle's going into a pumpkin here or is this like a Transaxle?)
Anything I'm missing?
Brake fl bleed/fill
Rotors/Pads
Fuel Filter
