Yesterday my driver side caliper froze up on me while driving home. I installed a new one and while bleeding the brakes (catching the fluid in an old taco bell cup) I noticed the fluid had black specs in it. I got to thinking about it after we were done and did some research, looks like the common theory is that the stock rubber brake lines deteriorate from the inside and can cause brake calipers to fail.
This might explain why I've gone through 4 front calipers and one rear caliper in 2 years.
I found some Goodrich stainless replacement lines
http://www.autoanything.com/brakes/61A3671A0A0.aspx
But it also appears that Skyjacker and Russell make stainless lines as well.
Has anyone had any experience with them? Which one fits the best, has good quality, or better yet, has anyone had a stainless line fail?
