2011 Prius - 98,000 miles
I was hearing a a rubber crunch-like noise that was only coming from the right-front corner when rolling over dips and speed bumps at a very very low speed.
I went under there with my pry-bar and was able to duplicate the noise by moving the lower-control arm up/down.
Replacing the control arm assembly ($175, ouch) appears to have solved the problem, though I'm starting to hear the noise from the left corner as well.
Old Bushing:
Untitled by thecritic89, on Flickr
New one:
Here's the weird part - the old bushing does not appear to be destroyed. There are small cracks in the bushing, but if you zoom in, you can "see thru" the old bushing. The new bushing does not appear to have any cracks at all.
I guess I'm not 100% sure that the old bushing was bad, but the noise seems to have mostly gone away (plus the car tracks noticeably straighter) ever since I did the replacement.
Old Bushing:
New one:
