Just purchased a one owner 2007 Hyundai Tucson with 44,000 miles on it.
The manual states, "use a high quality ethylene glycol coolant compatible with aluminum cooling systems.". Seriously, that is all it says. No specifics on using low or no silicates, boron free, with phosphates, etc.
The recommended flush is only 36000 miles which tells me it is the old style coolant they put in these.
I would like to use a very high quality long life type coolant that has no silicates, etc. to ensure the aluminum system is protected at longer than the silly 36000 mile flush recommendation.
Could I use Zerex Asian, Pentofrost a2, or other coolants designed for Asian cooling systems.
Also, doing it at home it would be impossible to get 100% of the old coolant out of the vehicle. That being said, I thought I read somewhere where you could mix IAC coolant with P-HOAT and be fine, i.e., no gelling or other issues.
Any help would be appreciated.
Thanks!
Thanks!
