I got an after market oil pressure switch for my car as the original one was going bad. It's the type with a pipe thread connection into the block. The replacement came with white sealant (Teflon?) applied to the threads.
It went in OK but as I tightened it I did noticed something. The tightening torque just kind of got firmer and firmer, there was no sharp rise in the torque you usually get when the threads go metal-to-metal.
I went to install the electrical connector but had problems, so I had to remove the oil pressure switch. It came out way too easy. I know I tightened it reasonably, but the torque to remove it was like nothing. I noticed the thread sealant was gone from the threads.
I sorted out the electrical connector problem. There was an insert in the connector that didn't belong (remember this was an after market part). I removed the insert and the connector worked fine.
I put two wraps of Teflon tape on the threads, one thread back from the nose of the sensor. When I reinstalled the switch it tightened up just right, firm resistance at first with a sharp torque rise as the pipe threads went metal-to-metal.
I ran the engine a bit and re-checked the tightness of the switch, it was fine.
I think they put too much thread sealant on those parts, something to look out for.
