I put a new engine in this 2007 Kia Spectra, it was from a 2010 Hyundai Elantra from LKQ. I swapped the original intake onto the new block. It sounds great but I have a problem after it warms up the idle starts surging up and down. I've tried several things listed below:
PO507 Idle too High
1. Cleaned throttle body
2. Cleaned IAC valve, and swapped another
3. Cleaned MAF sensor, and swapped another
4. New Intake Gasket (with extra RTV)
5. Replaced Valve Cover Gasket (with RTV where specified)
6. New Spark Plugs
7. Swapped Spark Plug Wires (not new but ok condition)
8. no tears in intake hose
9. pinched Solenoid Purge valve did not make any difference
10. visual inspect of brake booster vacuum line looks OK.
10. knocking on IAC valve made no difference
11. sprayed water everywhere, no changes in idle
12. in short, best i can tell no vacuum leaks
13. TPS sensor testing using a voltmeter seems to pass OK.
14. throttle cables are slightly loose and not tight.
15. PCV valve is ok, rattles when i shake it.
Engine surges up and down between 1200-1600
Short term Fuel pulses from 0 to +20% evenly
O2 Voltage pulses from .0 to .1 volts
Stuff I havent done yet:
smoke test to find vacuum leak
use a vacuum gauge? to see if it holds vacuum?
Obviously the fuel trim is off, and I believe the upstream O2 sensor voltage is too low, but I do not get an engine code. Also I *think* i'm getting no voltage from the rear O2 sensor but I need to re verify that, i tried several things at once and didnt do it methodically like i should have. What do ya'll think?
PO507 Idle too High
6. New Spark Plugs
