AZJeff, no there is no temp repair for the 2.5 as I tried them as well as the previous owner tried them. Unfortunately previous owner used some type of aftermarket headgasket repair seal where you pour it in the crankcase...it was a temporary fix that ultimately just made the situation worse in the end and the HG did fail externally. It's quite probable that your friends Forester has compromised valve seals and oil control rings failing miserably. Again, as I mentioned previously the smoke from the tailpipe is not a good test for Subarus since they come factory with a very efficient cat convertor (much better than average I'm told for when I went shopping for a replacement) and with that I'd suspect the oil burning is substantially masked while driving. The only time you will notice it is at start-up when the oil is pulled past the rings and sucked in past the valve seals. This is what occurred to mine.
AT-205 did not work for my situation even remotely which in hindsight is quite logically expected. Oh, for external oil leaks as I indicated mine had it would have to sit un-driven for at least a day or two before I witnessed any leaks on the garage floor. As it turned out it was leaking externally on both sides of the block rear corners but not nearly as bad as the oil control rings and valve seals were dumping out the exhaust.I'd recommend to your friend to not drive the vehicle if at all possible and deadline it until such time as he decides to save it or ditch it.The block will have to be pulled and torn down to, at a minimum, the heads to check the valve seals overall condition as well as the valves themselves for any burn. It's possible that is all it is but suspect more is going on farther down into the block(aka rings failing).I would agree that previous owner neglected the poor subie significantly which led to its demise. This is what occurred in my situation to and I paid the price. I love the car so much though overall that I just could not give it up. I'm glad I made that choice.
I'm so glad thats behind me and I have a new engine in it from CCR.
Originally Posted By: AZjeff
Fellas, I looked under this Subie from front to back and it's drier than a fish turd dipped in salt! Not a drop anywhere.. it must be going out the tailpipe.
I know he isn't going to want to drop much money on this car, are there any Hail Mary! last chance things to try? Assuming it has to be the oil rings and/or valve seals. I told him to look up ATP AT-205, is there a recipe and procedure that has gotten someone results for the possible fouled rings?
