So I just went outside and read the codes on the Buick using a paper clip. Here is what I have...
- 38 - brake switch circuit
- 41 - cylinder select error- mem-cal or ecm problem
- cam sensor circut (3.8 models)
- 42 - bypass or electronic spark timing (est) circuit
- 66 - pressure sensor or circuit air conditioning
- 67 - nothing listed on gm trouble codes site, do you know what this is?
What does this all mean? Car drives ok, here are all the issues it has..
- SOMETIMES wont start until you try two or three times, or give it gas
- bad wheel bearing(s)?
- front engine fans don't kick on (although they did during this test)
- A/C doesn't work but heat does.
- ABS light is on but brakes work fine.
So what do you say?
So what do you say?
