Having oil pressure issues after 5200 rpm or so.
61 psi @ 3500 rpm
61 psi @ 4000 rpm
62 psi @ 4500 rpm
62 psi @ 5000 rpm
55 psi @ 5500 rpm
50 psi @ 6000 rpm
48 psi @ 6500 rpm
54 psi @ 6900 rpm
81 psi was registered on cold start up
Info:
Rebuilt 6.1 hemi
.0025 main bearing clearance
.002 rod bearing clearance
positive displacement factory 6.1 oil pump. bypass listed as 65 psi. I have seen various ratings, including= 4.72 gph at 4000 rpm (quoted by melling to me), and 2.04@ 400 rpm & 4.54@ 2000 rpm (internet forum - user quoted melling)
piston oil squirters
hemi is top down oiler
straight 30 wt conventional (tests done at 170*F oil temp)
Bosch 3500 filter
Add'l- 6.1 factory spec oil is 5W-40 synthetic
What should I do to increase my oil pressure at 5500-7000 rpm? I have both a mobil 1 and k&n filter here to try (where does the bosch rate for flow restriction vs these two?). Also have various grade oils. Was going to install one of my oil pressure sensors before and one after filter for logging pressures - however I broke one (won't get new one till after weekend). I used the sensors to find other oil restrictions (one way check valve, oil cooler).
Any help is appreciated. Thanks!
61 psi @ 3500 rpm
61 psi @ 4000 rpm
62 psi @ 4500 rpm
62 psi @ 5000 rpm
55 psi @ 5500 rpm
50 psi @ 6000 rpm
48 psi @ 6500 rpm
54 psi @ 6900 rpm
Info:
Rebuilt 6.1 hemi
Bosch 3500 filter
