2012 Toy 4Runner rear open diff, LE1605, 30K miles
Magnolia, TX
2WD 2012 4runner with 31,713 miles on unit and 1605 SAE 110 ISO 220 was in service for 29,849 miles of it.
VOA UOA
Iron 1 303
Chromium 0 1
Nickel 0 0
Aluminum 0 0
Copper 0 0
Lead 0 0
Tin 0 0
Cadmium 0 0
Silver 0 0
Vanadium 0 0
Silicon 0 3
Sodium 0 1
Potassium 0 0
Titanium 0 0
Molybdenum 3 0
Antimony 0 0
Manganese 0 4
Lithium 1 0
Boron 88 52
Magnesium 0 0
Calcium 6 2
Barium 0 1
Phosphorous 1154 1100
Zinc 4 7
Water V40C 222 189
TAN 1.78 1.64
Oxidation 10
Nitration 4
In gear oils you have what is known as the EP additive which is a Sulfur-Phosphorus chemistry. The secondary EP is in most cases a Boron ester.
It is the sulfur AND phosphorus that gives it its odor.
The sulfur (not tested) is most likely at a level of >,= 3,500ppm.
There is a little bit of ZDDP in there to act as one of the anti-oxidants.
I read somewhere that the sulphur helps create a iron sulphide barrier to help protect gears. Is that true?
It is more like a ferrous-phosphide-sulphide film at the molecular level.
1605 also has another extreme pressure/AW additive that LE calls DUOLEC. I don't know if it stinks all by itself, but it seems to work. It doesn't show up as a metal on ICP though. Maybe someone here like Molakule knows what it is.
