Given that the fuel-diluted oil had a very low KV100=5.3, it may be a good idea to add some Polymer Ester (Hyper Lube no-zinc formula zinc replacement AW product) as MolaKule has used this kind of trick to get wear down in a low-viscosity oil.
Originally Posted By: MolaKule
I have used this kind of polymer chemistry in reduced ZDDP (experimental) formulations and I found I could reduce viscosity and still lower wear rates.
Suggested dossge ratio is about 1oz Hyper:13oz PCMO so what I suggest (since I don't see any viscosity or VII data) is adding 2-3oz of this stuff to a quart of oil and have the mix analyzed to make sure the VOA viscosity is still in the 0w20 range or whatever range of oil viscosity you may be using.
The polymer ester I use is about 140 weight (approx. 35 cSt) in its virgin form, but I suspect this stuff is "cut-down" to a 20 or 30 weight.
